Wireless Flow Meter next to a phone thumbnail
Wireless Flow Meter thumbnail
Wireless Flow Meter next to a phone and Rachio # controller thumbnail
Wireless Flow Meter against a brick wall and mentioning a leak detection thumbnail
Wireless Flow Meter against a wall thumbnail
Wireless Flow Meter
Smart Sprinkler Accessory
Reveal the true picture of your outdoor water use and stop leaks in a minute or less. Cutting-edge Rachio Wireless Flow Meter technology monitors outdoor water-use, halts costly leaks and protects your landscape from damage.The Rachio Wireless Flow Meter is only compatible with our latest technology, the Rachio 3 Smart Sprinkler Controller.
$119.99
Best-in-class support
Free shipping & returns
2-Year limited warranty
Rebates available
Stop leaks in a minute or less.
Only cutting-edge Rachio Wireless Flow Meter technology monitors outdoor water-use, halts costly leaks and protects your landscape from damage.
Works exclusively with long-range Rachio 3 Smart Sprinkler Controller technology.
Wireless Flow Meter talking to the Rachio App
Reveal the true picture of your outdoor water use.
Revolutionary Wireless Flow Meter technology pairs seamlessly with Rachio 3 and the Rachio App to uncover patterns or problems in the pipes below.
Stop Leaks
Measure with Accuracy
Identify Flow Problems
White Pixel Phone
How the Wireless Flow Meter Works.
Install the Wireless Flow Meter between your backflow preventer and valve box, then it will automatically pair with the Rachio 3 Smart Sprinkler Controller.
As you water each zone, the Wireless Flow Meter learns the baseline flow rate. If a leak is detected, Rachio will protect your landscape by sending an instant alert and shutting down only the affected zone.
Watch over your water with Vortex technology.
State-of-the-art Vortex technology measures flow rates with accuracy - down to the gallon per zone. Designed with no moving parts, this streamlined technology withstands winterization and continuous use without maintenance or repair.
Illustration of how the Wireless Flow Meter works
Professional installation recommended.
The Rachio Wireless Flow Meter is compatible with most irrigation systems; however, pipe size and material, installation location and more can affect installation requirements. Professional installation will get you up and running in no time!
Installation Assistance
Need help finding an installation professional? Let us connect you to a Rachio Pro!
Comfortable cutting pipes and getting your hands dirty? Use our Help Center to learn more about DIY installation.
We're here to help.
Questions or concerns about the Wireless Flow Meter? Reach out to our best-in-class Support team or explore the Help Center. We’re here for you every step of the way!
Contact Support
Support illustration
Wireless Flow Meter Technical Specifications
In the box
  • Rachio Wireless Flow Meter
  • Plastic battery cover
  • 2 AA batteries
  • 4 screws
  • Installation guide
Pairing & Calibration Requirements
  • Rachio 3 Smart Sprinkler Controller (not compatible with Rachio Generation 1 or Generation 2 controllers)
  • iOS or Android compatible device
  • iOS 10.3+ or Android 4.4+ (subject to change)
Installation Requirements
  • Compatible Pipe Material:
    Copper, PVC, PEX or SDR9 poly.
  • Pipe Length:
    Length requirements vary by installation type. Visit rachio.com/flow to make sure your pipe is compatible.
  • Pipe Size:
    ¾” or 1” in diameter (pipes greater than 1” in diameter are not recommended)
  • Fittings:
    Fittings matched to pipe size (not included with the Wireless Flow Meter)
  • Wi-Fi:
    2.4 or 5 GHz wireless network signal available at controller installation location
  • Range:
    Installation site must be within 300 feet of an installed Rachio controller.
  • Note:
    Rachio Wireless Flow Meter is intended for outdoor water use only
Size and Weight
  • 6" x 2.5" x 3.25"
  • 0.55 lbs
Power
  • Source:
    Two AA batteries
  • Life:
    Approximately 2 years with normal use
Operating Range
  • Instrument:
    Vortex Technology
  • Flow Range:
    .5 - 25.0 GPM
  • Accuracy:
    +/- 5%
  • Burst Pressure:
    350 PSI
  • Pressure Loss at 20 GPM:
    <1.5 PSI
Warranty
2-year limited warranty
Communication
  • Data Transmission:
    LoRa® wireless network
  • Range:
    330 ft (100 m) open air
  • External Interface:
    Indicator light for pairing with Rachio 3 Smart Controller
Environmental
  • Operating Temperature:
    32F to 120F; freeze-proof with no water in the system
  • Weatherproof; submersible to 3.3 ft (1 m) of water, no additional enclosure needed
  • Winterize system without removing flow sensor
Your Cart
Your cart is empty.
