Control From Anywhere
Control your watering from wherever you are. Troubleshooting broken nozzles or dry patches? Starting your system up for the spring? No problem.
- Activate your sprinklers in just a few taps with Quick Run
- Start, pause or cancel your schedule anytime, anywhere
- Easily test your sprinklers without having to walk back and forth
Understand Your Irrigation
Your sprinkler system is set up into zones that are activated from a controller. But it’s hard to remember which is which when they’re just wires connected to numbers. Rachio makes it easier to understand with images and names.
Simple Scheduling
The core function of any sprinkler controller is to run schedules at a pre-determined time. But your old controller might be difficult to navigate if you don’t have a manual handy.
We’ll provide recommendations but you set specific days and times for your watering (this is helpful if you have watering restrictions).
We’ll provide updated watering schedules on a daily or monthly basis; great for those that want to set it and forget it.
Easily set up regular watering for supporting new growth in your lawn.
Scheduling Adjustments
These activate if you have recently received a lot of rain or rain is expected soon
This modifies your run times based on the season so that you’re not watering the same in the early spring and the heat of the summer
This premium feature recommends schedule adjustments based on your forecast.
Monitor Usage
It’s important to know how all of these features are working so Rachio makes it easy to track your sprinkler system usage in minutes - not complicated metrics that are hard to understand.
Most users can expect to save 20% or more water compared to traditional controllers. That adds up to more money in your pocket and less wasted water.
For a limited time, order a Rachio Smart Sprinkler Controller and get a free MySoil Test Kit for Earth Day. Easily schedule and control your in-ground irrigation system and learn about what nutrients your soil needs. Keep your yard healthy while saving on your water bill. Integrates with Amazon Alexa and other smart home devices. Smart sprinkler controller installs in 30 minutes or less with no special tools. For more on technical specifications click here.
