BEST SELLER
Rachio Smart Sprinkler controller installed easily.
Rachio controller and smart phone showing free Rachio App features.
Rachio Smart Sprinkler Controller without cover, showing sprinkler wire terminals.
Rachio Smart Sprinkler Controller with cover being removed.
Outdoor Rachio Smart Sprinkler Controller with woman holding smart phone showing Rachio App Quick Run.
Smart Watering
Easily schedule and control your in-ground irrigation system with the Rachio 3 Smart Sprinkler Controller and the intuitive Rachio App (no monthly fees). Keep your yard healthy while saving on your water bill. Integrates with Amazon Alexa and other smart home devices. Installs in 30 minutes or less with no special tools. For more on technical specifications click here.
Choose a zone count:What is a zone count?
Technical Specifications
App Compatibility
iOS 10.3+ and Android 4.4+; subject to change. Mobile app is required to connect the controller to Wi-Fi.
Integrations
Works with, Amazon Alexa, Google Assistant, IFTTT, Alarm.com, SmartThings and more.
Zones
4-zone, 6-zone, 8-zone, 12-zone and 16-zone models.
Size and Weight
  • Dimensions: 9.1” x 5.5” x 1.4”
  • Weight: 1.05 Lbs
Power Specs
Rachio 3 FAQ
Rachio controllers come in 4, 8 and 16-zone variants and work with most in-ground irrigation systems. (If you use a pump start relay, some additional parts may be necessary.) You’ll also need an strong Wi-Fi where the controller will be installed and a smartphone to set up your schedules.
You bet! Our Shared Access feature allows you to share different levels of access with whomever you’d like!
Yes, but you will need to purchase a Weatherproof Enclosure for outdoor installations.
Yes, most customers can install a Rachio controller in 30 minutes or less without the need of any special tools. To mount the controller you may want to use drywall anchors (included) that require a drill and screwdriver.
