Your Sprinkler Controller Stopped Working, Here’s the Smartest Fix
Sprinkler controllers wear out after years of service. The good news is that today’s replacements are Wi-Fi enabled, easier to use, and built to last! Meet the Rachio Smart Sprinkler Controller, trusted by over a million yards nationwide.
If your old irrigation timer stopped working, it’s the perfect time to upgrade. Rachio helps you:
Whether you like to tackle projects yourself or prefer a little help, Rachio makes it simple.
Rachio Smart Sprinkler Controllers work with your existing irrigation system and connect to your home Wi-Fi network.
Rachio has been named Wirecutter’s Best Smart Sprinkler Controller for years. Available in 8 and 16-zone models, it works with almost any yard setup.
Buy today, install this weekend, and enjoy effortless watering.
These activate if you have recently received a lot of rain or rain is expected soon
This modifies your run times based on the season so that you’re not watering the same in the early spring and the heat of the summer
This premium feature recommends schedule adjustments based on your forecast.
Control your watering from wherever you are. Troubleshooting broken nozzles or dry patches? Starting your system up for the spring? No problem.
Your sprinkler system is set up into zones that are activated from a controller. But it’s hard to remember which is which when they’re just wires connected to numbers. Rachio makes it easier to understand with images and names.
The core function of any sprinkler controller is to run schedules at a pre-determined time. But your old controller might be difficult to navigate if you don’t have a manual handy.
We’ll provide recommendations but you set specific days and times for your watering (this is helpful if you have watering restrictions).
We’ll provide updated watering schedules on a daily or monthly basis; great for those that want to set it and forget it.
