Ditch the Dial
Rachio Smart Hose Timers make watering easy!
Why Go Smart?
No knobs or dials
No knobs or dials
Won't water in the rain
Flow detection
Flow detection
smart hose timer using Rachio app
Easy Setup Through the Rachio App
Program one valve in minutes or combine multiple valves into one schedule.
Turn Water On & Off
Remotely on Your Phone
Great for troubleshooting your irrigation equipment, adding a little extra water on warm days, or stopping a run if you don't think it's needed.
Multiple smart hose timer valves
Control Your Whole Yard
Install up to eight valves per WiFi Hub and make sure every part of your yard is getting the water it needs.
Schedule Simplicity
Set watering times for sunrise or sunset. No need to go back and forth setting schedules on traditional timers, we've got it all in one intuitive place.
So Many Ways To Water
Pepper garden smart watering
Drip Irrigation
It's easy to connect a Smart Hose Timer to a drip kit so that your garden beds get reliable watering whether you're at home or not.
Tree root watering
Tree Root Watering
Whether you're establishing a new tree or just keeping existing trees healthy, deep root watering is easy with Smart Hose Timer.
Spot watering
Spot Watering
For a few weeks every year, one part of your yard may need a little extra water on a regular basis – we can help with that.
Smart watering pools
Filling Pools
Pool getting a little low? It's easy to add extra water with a few taps in the Rachio App.
Foundation smart watering
Watering Your Foundation
In some parts of the country, like Texas, it's imperative that you water the soil around your foundation, let's automate it so you don't forget.
New vs. Outdated
Traditional timers can be confusing to schedule and unreliable if you’re not able to check them daily.
Features
Smart Hose Timer
Outdated Clock Timer
Remote control / water from anywhere
Smart Hose Timer
Checkmark
Close
Automatic rain skips
Smart Hose Timer
Checkmark
Close
Watering confirmations
Smart Hose Timer
Checkmark
Close
Hands-free watering
Smart Hose Timer
Checkmark
Close
Multiple schedules
Smart Hose Timer
Checkmark
Close
Flow alerts if faucet is off
Smart Hose Timer
Checkmark
Close
Low-battery alerts
Smart Hose Timer
Checkmark
Close
Watering history
Smart Hose Timer
Checkmark
Close
Works with Alexa & more
Smart Hose Timer
Checkmark
Close
BEST SELLER
Smart Hose Timer kit
RACHIO
Smart Hose Timer
Rachio Smart Hose Timer Kits come with one valve and one WiFi Hub. Each hub can connect to eight valves making it easy to expand your watering. No special tools are needed to install. Once everything is plugged in, you connect it to your home’s WiFi and we’ll walk you through schedule setup in the free Rachio App. This all usually takes less than 15 minutes.
